× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN102: SickRage add-on from Mhynlo 2016.09.10-1 - no web interface
relains
Tutor
Hi,
Till yesterday I used sickrage add-on from RNXTRAS but I ran into some problems so decided to change it to add-on from Mhynlo. I the ReadyNAS web interface the switch is ON position. I tried to check the status via terminal.
systemctl status fvapp-sickrage.service
I get "Active: active (running) since Sat 2016-12-24 11:08:19 CET; 56s ag".
In the config.xml there is a line:
<LaunchURL>http://localhost:8081/</LaunchURL>
When I type into the browser address http://readyns-ip:8081/ or http://readyns-ip:8081/home I've get ERR_CONNECTION_REFUSED and a blank page.
Does anybody know the solution?
Message 1 of 9
Accepted Solutions
relains
Tutor
Re: RN102: SickRage add-on from Mhynlo 2016.09.10-1 - no web interface
I've ended up buying SickRage add-on from RNXtras.com and this one works like a charm.
Message 9 of 9
All Replies
FramerV
NETGEAR Employee Retired
Hi relains,
Did the ReadyNAS undergo any firmware updates before the issue? What is the current firmware loaded on the ReadyNAS.
Message 2 of 9
relains
Tutor
I have 6.6.0 firmware for some time now, I updated it shortly after release.
Message 3 of 9
FramerV
Hi relains,
I see; there have issues with apps being incompatible with the new 6.6.0 and I cannot say for sure if this is affected by it.
Lets try to cover some of the basic things first:
1. Are you connecting within your network? If you are not, try to do port forwarding on your router (forward port 8081 to the IP of the NAS).
2. What browsers have you tried? Try others, also try clearing cache lower/disable your network protection (Anti-Virus, Malware detection, etc.)
3. You could also try other computers.
Message 4 of 9
relains
Tutor
Thanks for your reply.
a.d.1.
Yes, I'ts the local network.
a.d.2.
I've tried Chrome, Firefox, Internet Explorer, Edge. Clering cache or disabling Anti-Virus/Firewall dosen't help either.
a.d.3.
I've tried from 2 computers (Windows 10) and my Android phone.
Due to incompatibility issues SickRage isn't mentioned in the topic below:
https://community.netgear.com/t5/Community-Add-ons/Community-app-compatibility-with-ReadyNAS-OS-6-6-...
Message 5 of 9
FramerV
Hi relains,
I do not think that this is something that we can adjust on the ReadyNAS side. Have you tried getting in touch with the app developer?
Message 6 of 9
JennC
Hello relains,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Message 7 of 9
relains
Tutor
Unfortunetly my problem isn't resolved yet. I will try to contact plugin developoer and see if it helps.
Message 8 of 9
relains
Tutor
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 2787 views
  • 0 kudos
  • 3 in conversation
Announcements
