- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS 104 munin/perl problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there
I'm using Munin for monitoring my ReadyNAS 104 but after the last Firmware update to 6.9.0 my munin node stopped working. When I try to start one of the Munin plugins with munin-run I get the following message:
Can't locate English.pm in @INC (you may need to install the English module) (@INC contains: /etc/perl /usr/local/lib/arm-linux-gnueabi/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabi/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabi/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl) at /usr/share/perl5/Munin/Common/Defaults.pm line 9. BEGIN failed--compilation aborted at /usr/share/perl5/Munin/Common/Defaults.pm line 9. Compilation failed in require at /usr/sbin/munin-run line 31. BEGIN failed--compilation aborted at /usr/sbin/munin-run line 31.
So I'm thinking it has something to do with Perl missing some Modules. Unfortunately the new version of the ReadyNAS firmware seems to use a variation of perl that isn't supportet anymore by the regular debian sources cause when I try to
apt-get install perl-modules
I get the following conflicts
Reading package lists... Done Building dependency tree Reading state information... Done You might want to run 'apt-get -f install' to correct these: The following packages have unmet dependencies: dpkg : Breaks: libapache2-mod-php5 (< 5.6.4+dfsg-3~) but 5.4.35-0+deb7u2 is to be installed libdbd-mysql-perl : Depends: perlapi-5.14.2 but it is not installable libdbi-perl : Depends: perlapi-5.14.2 but it is not installable libgd2-xpm : Depends: libfontconfig1 (>= 2.9.0) but it is not going to be installed Depends: libfreetype6 (>= 2.2.1) but it is not going to be installed Depends: libjpeg8 (>= 8c) but it is not going to be installed liblist-moreutils-perl : Depends: perlapi-5.14.2 but it is not installable libsocket6-perl : Depends: perlapi-5.14.2 but it is not installable libxcb1 : Depends: libxau6 but it is not going to be installed openjdk-6-jre-headless : Depends: libjpeg8 but it is not going to be installed Depends: libfreetype6 (>= 2.2.1) but it is not going to be installed perl : Depends: perl-base (= 5.14.2-21+deb7u2) but 5.20.2-3+deb8u9 is to be installed perl-base : Breaks: perl (< 5.20.0~) but 5.14.2-21+deb7u2 is to be installed perl-modules : Breaks: perl (< 5.20.2~) but 5.14.2-21+deb7u2 is to be installed php5-gd : Depends: libfreetype6 (>= 2.2.1) but it is not going to be installed Depends: libjpeg8 (>= 8c) but it is not going to be installed php5-snmp : Depends: libsnmp15 (>= 5.4.3~dfsg) but it is not installable snmp : Depends: libsnmp15 (>= 5.4.3~dfsg) but it is not installable tzdata-java : Depends: tzdata (= 2015f-0+deb7u1) but 2017b-0+deb8u1 is to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Is there anything I can do about this? Is there a munin version that works with the new firmware or is it possible to install older versions of the missing perl modules? I don't want to break the ReadyNAS OS but also I don't want to lose munin monitoring.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Now that is strange. The Munin node on my ReadyNAS suddenly started working again. Without me doing anything to the system. No more error messages with munin-run. And the graphs show up on the server.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
