× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Readynas Pro 6 - Err Used disks Check RAIDar
PersianP
Hi everyone,
Yet again for the second time I find myself in unknown waters and issues with my unit.
I am running 6.4.2 (have been afraid of uprading) on legacy ReadyNAS Pro 6.
I was running 6x1TB drives and 1 HD broke few weeks back and I have not had time to replace.
I woke upp some days ago to an unrespsonive NAS, could not reach it
So I performed a hard reboot, keep powerbutton pushed.
After the reboot I am now confrontend with this message:
ERR: Used disks
Check Raidar
I have found previous forum post and it seem to be related to OS partition not working?
I am hoping that mdgm can once again save me please.
Message 1 of 6
Sandshark
Sensei
Re: Readynas Pro 6 - Err Used disks Check RAIDar
OK, so did you check RAIDar?  What did it say?  How many active drives are shown?
Unfortunately, it sounds like you may have lost a second drive, and with it your entire volume.  The message is basically telling you it wants to create a new volume, but there is already something on the drives and you need to confirm it is OK to erase them.
Message 2 of 6
PersianP
I checked with RAIDar now and it does not show any disks.
Said something about dirty disk and that I needed to Format a newly added disk.
Really hope I do not lose my data volume 😞
Message 3 of 6
PersianP
Wohaa I tried removing the one drive I knew was "bad", I had not taken it out before, was still in the slot during this time it had failed.
Tried reboot with slot empty and only 5 drives and now it worked!
Tomorrow it is time for a visit at the local PC store to buy new drives and also a backup wd passport drive 🙂
Message 4 of 6
Sandshark
Sensei
Good.  Yes, rarely one bad drive can take down the entire SATA subsystem.  When you do replce the bad drive, do so with the power on.  That gives you more knowlege of what is going on because the GUI is already booted.
Message 5 of 6
Guru
It's best to use a USB drive that is not powered from the USB port (that is, has it's own power brick).
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2277 views
  • 0 kudos
  • 3 in conversation
Announcements
