× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Replacement for Tiny Tiny RSS or Selfoss
cat50998
Follower
I have a Readynas 312 running os 6.9.3. I had Selfoss and at one point Tiny Tiny Rss installed on my nas. They haven't been updated in years. Anyone have a recommendation for a replacement?
Message 1 of 3
Marc_V
NETGEAR Employee Retired
Re: Replacement for Tiny Tiny RSS or Selfoss
Hi @cat50998
Welcome to the Community!
Are you getting issues with the current firmware? I would suggest using the same RSS feed reader if you are not getting any issues with it. Contacting the developer is also an option to check if there are any updates available for the App.
Other Community members might be able to share the App they use.
Regards
Message 2 of 3
Marc_V
Hi @cat50998
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1545 views
  • 0 kudos
  • 2 in conversation
Announcements
