× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Sabnzbd, Couchpotato fail to start
Dinobe
Since a while some of the addons which I have installed on my readynas ultra 6 fail to start.
I downloaded sabznb a couple of years ago from the readynas extra's site.
When trying to start them from the frontview, I get the message 'Sabnz failed to start'.
While looking for the logs from the frontview, I found the following error: /etc/frontview/addons/bin/GLIBC6/start.sh" failed to start
this error is appearing a lot in the user.log file.
when doing and apt-get check I'm getting the following result:
apt-get check
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run `apt-get -f install' to correct these.
The following packages have unmet dependencies:
  couchpotato: Depends: python (< 2.8) but it is not installable
               Depends: python (>= 2.7) but it is not installable
  libc-bin: Breaks: libc6 (< 2.10)
  libc6-i686: PreDepends: libc6 (= 2.13-38+deb7u8.0)
  sabnzbdplus-theme-knockstrap: Depends: sabnzbdplus (= 0.7.16-0rnx1) but it is not installable
E: Unmet dependencies. Try using -f.
Guess I'll have to fix the libc6, question is, how?
Message 1 of 2
Guru
Re: Sabnzbd, Couchpotato fail to start
@WhoCares_ kindly provided a free add-on that updates libc6 for OS 4.2.x.  You can find it here: https://rnxtras.com/readynas-os4-x86
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2338 views
  • 0 kudos
  • 2 in conversation
Announcements
