Reply
Re: Sparc platform development envrionment using Qemu
airwofl wrote:
Don't worry - got it working on Windows in the end. Needed the openbios-sparc32 compiled for Windows.
You can get it from the QEMU website under the Windows download page - look for the SPARC binary.
hi,
it seems that the qemu website changed. I cant find the openbios-sparc32 windows binary. It seems that it was removed. Can plz someone upload it?
greetings
The QEMU image is not based on RAIDiator, so you can't upgrade the QEMU image to 4.1.7. It is just a Sparc emulated Debian Linux, that can be used to compile code to run on the ReadyNAS.
So, if I compile something on the QEMU virtual machine, is the resulting object binary compatible with the NV+ ?
ie Can I just copy and run, or do we have to recompile the source on the NV+ ?
What OS is actually running on the NV+ ?
Hi Everyone,
Could someone please post a working openbios-sparc32 file for my dev environment below:
Ubuntu on x86-64 - 11.04.
I'm having real trouble finding one that works...
Thanks!
Hmm... I'm running the images with the with "Q" ( the Mac qemu-Port ) and after starting apache and hitting HTTP the CPU usage spikes so bad that Chrome times out over an over again... I am trying to run Q on a MacBook Pro, but's I'm surprised it's this slow.
Also Frontview is empty?
Is this expected? Do I need to boot up some other services? Or is this image really just for building other stuff not emulating the full ReadyNAS?
-Thx
ReadyNas Pro, NV+, Duo
kayjaywt wrote:
Hi Everyone,
Thanks!
You are not alone in that. Guys, suggest something if there is. Grateful!
NETGEAR Moderator
Developers running Windows 7 may wish to take a look at this video by @syke:
I can do another one for recent versions of Linux/MacOS if need be, but this one is detailed enough that users of other platforms should be able to translate the steps.
I hope this helps, please leave feedback and thumbs it up. If anyone is in the giving mood after watching, please buy some of my band's songs @ http://themakingofthemakingof.com Smiley Happy
Hello,
I tried to run qemu under windows7 by using the image. But when I enter the command as in the video posted nothing happens. As you said, there will no error be displayed I have no idea what I did wrong.
Uploaded with ImageShack.us
@fme_: Try "ifname" instead of "iframe"
Great video, I'm up and running with the Qemu dev env. Now to have a crack at getting bluetooth support working...
So, the past days I got time to try this qemu thing again, and now its working! Smiley Happy Thanks matt_hargett . Is there also a way to access the webinterface of the nas? Entering the IP Adress of the qemu results into a 404 error. (running it on windows7 with enabled iis)
EDIT:
You have to start the service by your self. /etc/init.d/frontview start
and
passwd admin
Enter new UNIX password:
Retype new UNIX password:
Discussion Stats
Top Contributors
User Kudos Count
1
