super_poussin's avatar
Aug 10, 2008
Xplorer (aka AjaxPlorer)
XPLORER
  • Description: Xplorer is a powerfull explorer based on Ajax.
    AjaXplorer is an easy-to-install file explorer for remotely managing files on a web server. Its “rich client” layout and actions make it accessible to any end-user for a variety of purposes: file management/sharing, photo gallery, code browsing, etc. Only PHP (4 or 5) is necessary, no database needed.
  • Requirements: RAIDiator 4.1.5+ and PHP add-on or PHP-GD add-on (better but you will loose squeezecenter support)
  • Platform: Sparc
  • Current Version: 5.0
    Xplorer 5.0(Ajaxplorer 4.0.1) (01/04/12)
    Xplorer 4.1(Ajaxplorer 3.2.1) (02/22/11)
    Xplorer 4.0(Ajaxplorer 3.03) (11/04/10)
    Xplorer with Ajaxplorer 2.7.2 alpha (05/17/10)
    Xplorer 3.52(Ajaxplorer 2.6.1) (05/17/10)
    • based on ajaxplorer 3.2.1 :
        • Iphone support
          CORE ENHANCEMENTS:
          • Huge optimization (30% perf) using xdebug : cache registry and required files.
          • « Columns Template » concept to enable columns width save in repositories like ajxp_conf. Missing updateIcon() implementation when loading a subfolder at startup. Do not display empty lines in logs.
          • Remove old USERS_DIR constant that was in fact useless, and deported folders checks inside drivers (new performChecks function in AJXP_Plugin).
          • ConfService now stores errors at initialisation, which can be checked for alerting user of misconfiguration.
          • Introduce AJXP_LAST_KNOWN_VERSION to cookie to issue an alert message on version update and invite user to clear the cache.
          • [gui.mobile] iPhone adaptation : touch events, display optimization, and much more. Small changes in initTemplates (backward compatible) to support scripts & css insertion.
          NEW PLUGINS :
          • [log.sql] Stores all ajaxplorer logs in a DB instead of files
          • [editor.codemirror] New source viewer with inline syntax highlighting, replaces CodePress.
          • [Access.smb] & [auth.smb] Browse a samba server (based on smbclient commandline tool).
          • [editor.video] Video-js integration (better support of mp4, ogv and webm formats)
          EXTERNAL BRIDGES:
          • [Wordpress] Important Security Update! Upgrade is highly recommanded.
          • [Joomla] New version of the plugin, compatible with Joomla! 1.6
          PLUGINS FIXES:
          • [conf.sql] Add a USERS_DIRPATH option for storing the temporary data, instead of hardcoding /server/users
          • [auth.ldap] LDAP Remur patches
          • [uploader.jumploader] Was broken in 3.2
          • [uploader.html] Calling form.reset() was breaking the upload options after adding a file to the list… Use xhr.onreadystatechange instead of xhr.upload.onload , seems to be better supported by Chrome (fixes the « loaded » state)
          • [access.fs] Fix various issues with recursivity and file/dir choice. Chmod value was not correctly applied.
          • [access.ftp] FTP Upload broken
          • [access.sql] SQL Pagination broken
          MISC FIXES:
          • Disable « Share Folder » if the Auth driver implementation cannot edit the users.
          • Fix location bar autocompleter : clicking on a choice does not trigger the context to change.
          • i18n : Force replacing the newline (double antislah) to be sure the language will dynamically reload.
          • Declare skipSecureToken in action. Warning, action must be declared directly inside manifest.xml, not in inclusions.
          • Woodruff enhancements : users custom data (sample commented in conf file), and « full » list modes for displaying grid contents on multiple lines.
          • Warning on filename truncation at upload
          • Always stripScripts() in message
          • Ajxp link was broken if users not enabled
          • Fix disappearing favicon in FF after updating location.hash
      • based on ajaxplorer 3.0.3 :
          3.0.3
        • Next addon version will preserve your settings :)
        • New Plugins
          • Meta.svn : Replaces access.remote_svn and access.svn. Based on the presence of the svn command in the command line and to be used with a working copy. Auto-commit files on add/move/delete, etc, and display SNV Log.
          • Dynamic FTP proxy server & FTP authentication : several people asked for it, here it is! Use an ftp credential to log your users in, or even transform AjaXplorer into a « blank » ftp proxy, and users must fill the FTP server data at login time.
          • Meta.Exif : Simple Exif data reader, based on PHP exif functions. Can be used conjunctly with editor.openlayer (cf below).
          • editor.openlayer : OpenLayers.org map system, can display any layers, like Google Maps or OpenStreeMaps, or WMS layers. Used by meta.exif if geolocation found in exif data (see demo!)
          • WebDAV driver, based on fsDriver+PEAR WebDAV Client (Jejem work).
            2.6.1
          • Minor version, still enhancing the security, fixing non-flash upload for FTP plugin, and fixing the auth.remote plugin
            2.7.2
          • , the 2.72 fixes a great number of bugs, improves layouts on many way, introduce the PDF viewer via ImageMagick, etc
        • What's new :
          • Security Fix
          • you can now access it using https://@nasip/explorer/
            • NEW FEATURES :
              • Added « Compress » action to create a zip on the server
              • Added Google Analytics optional support : log page access and download events.
              • New configs to enable/disable flash uploader, and to enable/disable multiple Zip download.
              • Implement natural sorting
              • Massive unification of the GUI between the flash uploader and the html uploader. [Prototypization of MultipleUplaoder and MultipleDownloader]
              • Layout persistance across sessions : diaporama behaviour, splitters sizes, display state (list or thumb) and thumb size.
              • Auto rename files to allow same folder copy.
              • Added sorting for users and repositories listing. Sorted repository list in interface.
              • Added Troubleshooting.txt, base for very basic problems, to update regularly
            • BUG FIXES :
              • Icons update in the upload
              • Fixed E_NOTICE detection
              • Allow deletion of multiple user/repo’s selection in setting
              • Real size probing fix for users having issues for downloading
              • Test if »Session dir » is writeable
              • Improved error catching.
              • Fix « Recycle Bin not created » problem.
              • Repository list width problem in Firefox (repositories with huge names)
              • Improved repositories edition pane layout.
              • Remove auto-switch to list when paginating
              • Fixed file permission window on Opera
            • AND AMONG OTHERS …
              • Fix IE8 line breaks problem.
              • Copy Dialog : if ability to copy in other repositories, the select box is now on <Current Repository> by default.
        • Installation Notes: you need to install PHP addon if not already done
        • Screenshots:
ProSupport for Business
