× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
couchpotato fails to start
NTGR-OPS
Tutor
Well, I know this might seem like an old topic, but I cannot find an answer and after several hours trying everthing I can think of on my own, have decided to reach out to the experts.
I had Couchpotato 3.0.1-1 working, wne away for a week, came back and it wasn't running.  Attempts to start it gave me an error.  Something akin to "failed to start".
I've actually seen this before, and have reuploaded the package in the past with success.  This time no luck.
Tried deleting the file useing a combination of purge and rm commands, and tried to reinstall.
The system tells me that "System: Application couchpotato is installed successfully.".  But it's not.
Tried rebooting, loading 3.0.1, then updating to 3.0.1-1, nope.
This error if i try to remove the app.
root@ReadyNAS:/apps# apt-get remove couchpotato
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages will be REMOVED:
couchpotato
0 upgraded, 0 newly installed, 1 to remove and 79 not upgraded.
After this operation, 10.2 MB disk space will be freed.
Do you want to continue? [Y/n] Y
(Reading database ... 34302 files and directories currently installed.)
Removing couchpotato (3.0.1-1) ...
Failed to stop fvapp-couchpotato.service: Unit fvapp-couchpotato.service not loaded.
dpkg: error processing package couchpotato (--remove):
subprocess installed pre-removal script returned error exit status 5
Errors were encountered while processing:
couchpotato
E: Sub-process /usr/bin/dpkg returned an error code (1)
I'm lost and need help.
Message 1 of 6
Accepted Solutions
NTGR-OPS
Tutor
Re: couchpotato fails to start
Found new version on GIT.  Seems to have fixed it.
Message 4 of 6
All Replies
JennC
NETGEAR Employee Retired
Hello NTGR-OPS,
What's the model number of your NAS and its firmware version?
If it is ReadyNAS OS6 firmware, can you post what you get from install_debpkg.log?
Message 2 of 6
NTGR-OPS
Tutor
Log sent.  Thanks for your help.
RN31600
6.7.4
Someone suggested this?
Remove this from /var/lib/ddpkg/status, and reinstall.  i'm concerned about the purge ok installed status.
Package: couchpotato
Status: purge ok installed
Priority: extra
Section: contrib
Installed-Size: 9980
Maintainer: Mhynlo <mhynlo@mhynlo.io>
Architecture: all
Version: 3.0.1-1
Depends: readynasos (>= 6.1.0), php5-sqlite, python, git
Description: CouchPotato
Automatic Movie Downloading via NZBs & Torrents.
Homepage: https://couchpota.to/
also, reinstalling fails.
root@ReadyNAS:~# apt-get install --reinstall couchpotato
Reinstallation of couchpotato is not possible, it cannot be downloaded.
0 upgraded, 0 newly installed, 0 to remove and 79 not upgraded.
Message 3 of 6
NTGR-OPS
Tutor
Message 4 of 6
kceefan64
I couldn't find an update, could you please post the location when able? TY
Message 5 of 6
kceefan64
Nevermind, I tried uploading, for the 5-6 time, the latest file I have and CP is loading...for now.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 4583 views
  • 0 kudos
  • 3 in conversation
Announcements
