Orbi WiFi 7 RBE973
Reply
Some character strings not properly rendered by forum software.
Guru
If I enter data followed by : the forum renders it as data:
It is possible to edit the html to fix it - if you use <strong>data</strong><strong>:</strong> you get data:
But you shouldn't have to do this.
Message 1 of 2
KennethL
NETGEAR Employee Retired
Re: Some character strings not properly rendered by forum software.
Hello @StephenB
The replacement to data&colon; is a security measure to prevent Cross Site Scripting XSS.  It just happens your combination of "data" followed by either ":" or "&colon" will be filtered out with replacement text.
Community users will have a replacement   data;      Certain roles, like, moderators, community managers, administrators will have replacement text    data&colon;
Some XSS attacks are listed >>  xss attack vectors  https://gist.github.com/soaj1664/9588791
For signatures, the combination of "data" followed by either ":" or "&colon" will be filtered out with replacement text data&colon;    The workaround is the one you provided <strong>data</strong><strong>:</strong>
Another less obvious html       data<i>:</i>
Kenneth
Community Manager
Message 2 of 2
Discussion stats
  • 1 reply
  • 3725 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
