Orbi WiFi 7 RBE973
GS105PE PoE+ Interoperability Issues
schumaku
Guru
Dear John, Long time no hear.
Chiming in here because of some ongoing issues for some GS105PE customers reporting the GS105PE does fall-back to .af on the port 5 PD (powered on PoE+ switches) on various switch models/brands so there is not enough power available to power some more demanding devices - but all within the specs. The issue does not show up in my testing grounds or with my customers, so afraid I can't help - beyond of testing potential updates and fixes for recursions.
-> GS105PE Firmware Update V1.5.0.5 breaks POE passthrough (and no, the problem is not 1.5.0.5 specific).
Thank you for taking care!
-Kurt
Model: GS105PE|ProSafe Plus 5 ports switch with PoE pass through
Message 1 of 2
DaneA
NETGEAR Employee Retired
Re: GS105PE PoE+ Interoperability Issues
Hi @schumaku,
I inquired this forum thread and other similar forum threads about the GS105PE switch to the higher tier of NETGEAR Support.  As per the higher tier of NETGEAR Support, one of the community members who posted needs to get a valid support ticket raised to the NETGEAR Support Team so that logs can be forwarded to the engineering team for further investigation.
If ever there is already an ongoing case, a follow-up should be done by the NETGEAR Support Team to get the necessary details such as logs and config file in order to be escalated to the engineering team.
DaneA
NETGEAR Community Team
Message 2 of 2
Discussion stats
  • 1 reply
  • 7162 views
  • 1 kudo
  • 2 in conversation
Announcements
