× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
Reply
5g connection on my c3700 does not work until manual restart
aravindgan
Follower
I have this problem for quite sometime, comcast confirmed its the issue on modem+router.
The 5g connection keeps dropping and unless i take a manual restart it would not work.
LAN and 2.4g works fine.
My firmware is the latest and Comcast/xfinity confirmed its the latest firmware.
Please advice steps to fix this.
Aravind.
Model: DGND3700|N600 WIRELESS DUAL BAND GIGABIT ADSL2+ MODEM ROUTER
Message 1 of 5
DarrenM
Sr. NETGEAR Moderator
Re: 5g connection on my c3700 does not work until manual restart
Hello aravindgan
Have you tried to change the 5ghz channel in the wireless settings?
DarrenM
Message 2 of 5
Krisstir
I am having the same problem with my modem, how do you change the channel on it? Both the 2.4 and the 5g have blinking lights on the front of the modem.
Message 3 of 5
DarrenM
Hello krisstir
Here is how to change the channel
https://kb.netgear.com/23783/Improving-2-4Ghz-Wireless-Performance-by-Changing-Channel
DarrenM
Message 4 of 5
mccallum42
Anyone have a fix for this issue? It started for me about a month ago.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3488 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
