Orbi WiFi 7 RBE973
Reply
BT compatibility with Nighthawk modem router D7000
ntangle
Follower
Got a D7000 the other day and plugged into my adsl line. It was very responsive for a short while, and then the genie would tell me I am not connected to the internet, even though the light is white and I had stats.
From one of the computers I did a ping to 8.8.8.8
they were fluctuating between 2000ms up to 8500ms. I would do a change like the mtu to 1544 and apply it. When the connection came back up from the change it would show a ping of 30-40ms for about 30s to 5 mins or sometimes a bit more then they would shoot back up to 6000-8000
I have been requested to change the MTU and that has not fixed it, also tried all firmwares available.
I went and swapped the unit at my local store today. It ran for about 3 hrs then started to do the same again!
Netgear support seem to be a bit disinterested now as it seem to tick the too hard box
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 2
clithes
Prodigy
Re: BT compatibility with Nighthawk modem router D7000
Could probably still be MTU setting
Here's an easy guide to follow to work out your correct setting:
http://www.tp-link.us/FAQ-190.html
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2909 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
