Orbi WiFi 7 RBE973
Reply
Can I make my Netgear DGND3700V2 as a wireless extender, without hooking it up with LAN cable?
akapoor
I was wondering if i can use my Netgear N600 modem router as wireless extender without having to physically connect the LAN cable to my current wireless modem router?
I can only find ways to make it as an access point and that to, hooking them both physically with LAN cable all the time. I there any way around it?
Thank you
Model: DGND3700v2|N600 WIRELESS DUAL BAND GIGABIT ADSL2+ MODEM ROUTER
Message 1 of 4
TheEther
Guru
Re: Can I make my Netgear DGND3700V2 as a wireless extender, without hooking it up with LAN cable?
Netgear routers function poorly or not at all as extenders.  Don't bother.
Message 2 of 4
You mean you want the DGND3700V2 to operate as a repeater?
Have you read the manual on that?
DGND3700v2 | Product | Support | NETGEAR
See page 102.
Message 3 of 4
akapoor
Hi Michael, thank your for your reponse.
Yes, i am trying to extend the wireless range using my N600 wireless modem router.
I have read thourgh the manual and tried setting it up accordingly. However, it wont allow me to enable the wireless repeating function as the 'channel is set on auto'. I cannot figure out what channel i would need to select to enable wireless repaeating function.
Thank you in anticipation
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 5829 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
