Orbi WiFi 7 RBE973
Reply
Can't connect to Spotify via iPad thru Netgear D7800
alexw_1958
Follower
I have a D7800 modem router.  I also have a Pioneer N50a music streamer.  Previously I have been able to stream Spotify from my iPad but now when I try to connect to the N50a via the iPad it doesn't work.  The N50a shows as an available device but when I select it, it tries to connect but eventually times out.  Streaming from the iPad in this way has worked in the past.
I have reset the D7800; I have deleted the Spotify app from the iPad and reinstalled and I have taken the N50a to a service agent and they have been able to connect to the N50a via this method on their network.
So it would seem to be an issue on my network.  I allowed Netgear setup to automatically configure.
Out of ideas.  Appreciate help.
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Can't connect to Spotify via iPad thru Netgear D7800
Have you looked to see if any port forwarding is needed for the N50a?
DarrenM
Message 2 of 2
Discussion stats
  • 1 reply
  • 2359 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
