Orbi WiFi 7 RBE973
Reply
D500 N150 WIFI DSL MODEM ROUTER. WIFI TROUBLE AFTER POWER CYCLE
shaileshmurali
whenever i turn off my router than turn on i dont get automatically connected to internet, i have to go to browser enter 192.168.1.1 and do the setting again n again after every power cycle.
is there any solution to get connected automatically?
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: D500 N150 WIFI DSL MODEM ROUTER. WIFI TROUBLE AFTER POWER CYCLE
Hello Shaileshmurali
Are you using the latest firmware if not try updating and see if the issue is still happening.
DarrenM
Message 2 of 4
shaileshmurali
hii darren,
im using latest firmware Router Firmware Version
V1.0.0.20_1.0.1PE still the issue is not solved
Message 3 of 4
DarrenM
Maybe the DSL signal is low do you have a DSl filter on the line maybe try to check the connections unplug them and back in make sure its all tight and good. If that is not the issue you could always back up your modem config file and try to factory reset the modem.
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1857 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
