Orbi WiFi 7 RBE973
Reply
D6200 Port Forward Help
PRESJAR
Hi,
I have read the kb article:
http://kb.netgear.com/app/answers/detail/a_id/24046/~/how-do-i-configure-port-forwarding-on-routers-...
This shows the Netgear Genie interface allowing the mapping of an external port to a different internal port. I wish to direct port 80 of my public IP address to forward to port 5000 of my internal network IP 192.168.0.5. (External_IP:80 forward to 192.168.0.5:5000) On my D6200 the option to forward an external port to a different internal port is not visible as show in the KB example. I can only see Start Port and End Port when adding a custom service.
Message 1 of 5
Accepted Solutions
TheEther
Guru
Re: D6200 Port Forward Help
Judging from the manual, I believe the D6200 doesn't have ability to translate an external port to a different internal port.
Message 2 of 5
All Replies
TheEther
Guru
Message 2 of 5
PRESJAR
Ah man... what garbage. Software crippled! It was not cheap either. Kinda false advertising in that KB article hey. It uses the genie interface.
Looks like upgrade time 😞
Message 3 of 5
PRESJAR
What feature is the manual am I looking for when buying a new router to ensure the internal/external translation function works?
Message 4 of 5
TheEther
Guru
It's still port forwarding. You just have to make sure that it supports the ability to uncheck the button to use the same internal and external ports.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 5386 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
