Orbi WiFi 7 RBE973
Reply
D6200 and Netgear Genie Version 2.4.38
krpp1801
Follower
my Genie Windows appl suddenly says it does not support the D6200 router, which I installed WITH the Genie a while ago. The Genie s/w has since been upgraded to the 2.4.38 ver, Ican see all the network stats and links and run speed tests wit Genie, but cannot log into the router.
however, my iPhone ^ genie app canlog into it and manage it, except for a few detailed areas.
where do I find an older or better ver of Genie, it used to work on this router.
Thks for the help.
Model: D6200|Dual Band 11ac ADSL Modem Router
Message 1 of 2
Re: D6200 and Netgear Genie Version 2.4.38
What happens when you try?
Can you get in with the Windows desktop genie by giving it the IP address of the modem?
I find it easier to use the web browser to get in and do things.
Does your D6200 have the latest firmware?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2499 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
