Orbi WiFi 7 RBE973
Reply
D6200 bridge to TalkTalk modem
ot221268
Hi - I have TT super router and wish to ise the D6200 wireless capabilities. I have found instructions and connections on the TT forum and connected TT SR LAN to Fibre port on D6200.
What I can't figure out now is how can I log into the D6200 to make the changes requried? Because it is not directly connected to the PC, routerlogin has no function. What I need to do on D6200 is...........
Set WAN connection to DHCP/Automatic IP
I cannot access D6200 via Genie.
Any suggestions please?
Message 1 of 4
Fairytail
Virtuoso
Re: D6200 bridge to TalkTalk modem
For you to access the D6200 page, you have to connect a computer directly to it. Check the IP and access it using the defualt gateway.
Message 2 of 4
ot221268
Thanks - that's what I thought. I presume then that I would reconect the TT router to the PC to make the changes to it's settings?
Message 3 of 4
Fairytail
Virtuoso
When you are connected to another router, although the router is connected to teh modem, it will have a different network since both router are running a DHCP.
Message 4 of 4
Discussion stats
  • 3 replies
  • 4731 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
