- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D6200 has no internet connection until power cycled
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
Over the last week or so my internet connection has been having issues. After a certain amount of time without use (ie while I'm at work) if I then attempt to use the internet there is no connection until I power cycle my modem/router (D6200). After this I have no issue until next time the connection is idle for a time.
I can connect to the modem/router via the wifi so I know the issue isn't the wifi connection.
When there's no internt there is no indication from the modem/router that there is any problem, no flashing lights, every light is the colour it chould be (green/blue).
I don't have the home phone connected so there is no splitter on the internet connection and this is the only phone outlet I have.
Any help appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D6200 has no internet connection until power cycled
I'm a bit confused. Does this mean that you can still connect to the Internet using wifi before you restart the modem?
If so, it may be a local network (LAN) issue. Is it a wired connection that loses the Internet?
Is the a DSL filter though? You need that even without a phone.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, thanks for the reply. The LAN is working (both wifi and wired) so I can look at the modem details, the modem router dealing with the incomming internet connection seems to have the issue. There is a DSL filter on the line but no splitter. I have no connection issues whilst I'm using the internet, just after its been idle for a while. Again, thanks for the help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> Is the[re?] a DSL filter though? You need that even without a phone.
Not really. The whole purpose of a DSL filter is to keep the
high-frequency DSL data signal away from plain-old telephones. A DSL
modem should be connected directly to the phone line. An ordinary
telephone must be isolated from the phone line by a DSL filter.
One type of DSL filter, which may be called a "splitter", simply
provides one directly-connected ("DSL") port, and one filtered ("PHONE")
port.
No phone? No filter needed.
> [...] There is a DSL filter on the line but no splitter. [...]
_That_ sounds troubling. How, exactly, is this (unnecessary?) filter
connected? Feeding a DSL modem through a filter sounds like a good way
to get a very poor DSL signal.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ClaireLC wrote:
....I have previously have all my equipment fried by a lightning strike!
That's one reason for using a DSL filter, even when you don't have a phone. (A filter is also useful when you phone socket and modem socket are different, as they are in the UK, where you would have a hard time plugging a modem into the phone's wall socket.)
Lightning got me some years ago, hit the overhead phone line, took out a bunch of kit. (Remember fax machines?) The PC died because it had an on-board dial-up modem with a direct connection into the phone socket.
Anything between the important stuff – modems and things that cost money – can act as a buffer. It gets fried before the bits after it. No guarantees, of course, but every little bit helps.
- Bookmark
- Subscribe
- Permalink
> [...] the line actually runs through a power board (for electrical
> isolation [...]
Without actually looking at its innards, or making some measurements
beyond the capability of typical household test equipment, it's hard to
say if such a surge/transient protective device would bother a DSL
signal. However, if your D6200 web interface looks like that of my
D7000, then you could look at ADVANCED > ADVANCED Home : Internet Port :
Show Statistics, and see if the Link Rate, Line Attenuation, and Noise
Margin values change significantly when the extra gizmo is inserted or
removed. A change of one or two dB in the latter two values would
probably be insignificant, but a bigger degradation might matter more.
> phone. [...]
Not really. At least, not using the commonly accepted definition of
"DSL filter":
https://en.wikipedia.org/wiki/DSL_filter
A protective device (_not_ a "DSL filter") on the phone line may be
valuable, unless it degrades the (high-frequency) DSL signal. The fact
remains that a DSL filter (as normally defined) goes between a phone
line and a normal telephone (or other analog telephone-like device), not
between a phone line and a DSL modem.
In a DSL filter-splitter, the phone line is connected directly to the
DSL port; the filter part goes between phone line and the "PHONE" port.
A DSL filter-splitter provides no more protection to a DSL device than
any other passive phone-line coupler would (that is, practically none).
- Mark as New
- Bookmark
- Subscribe
- Permalink
