Orbi WiFi 7 RBE973
Reply
D6300 ca i connect to a wireless router
wirelessK1
I recently moved and i had to get a wireless broadband connection as there is no wiring available. I have the Huawei E5776.
Can I connect the D6300 to the Huawei and use the D6300 as my AP?
If so, is there any doco I can follow to set it up?
I see information on connecting via a cable to another router but the Huawei doesn't allow that.
Message 1 of 3
WizardJ
Luminary
Re: D6300 ca i connect to a wireless router
If the E5776 supports WDS, you can set it up as a wireless base station, and then set the D6300 up as a wireless repeater. 🙂
Instructions to do this on the D6300 are on page 99 of its manual: http://www.downloads.netgear.com/files/GDC/D6300/D6300_UM_19Nov2013.pdf
Message 2 of 3
wirelessK1
Brilliant
thanks for the help 😄
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3894 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
