× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
Reply
D6400 Aus NBN help (belong fttp)
Astaraxia
Hi there, I’m a newbie and was wondering if there were any guides or settings available on how to hook up my d6400 to Australian NBN? Belong isn’t very helpful and they’re only recommending that I use their modem which hasn’t arrived twice now. Would appreciate any help!
Model: D6400|AC1600 WiFi VDSL/ADSL Modem Router|802.11ac Dual Band Gigabit
Message 1 of 4
Re: D6400 Aus NBN help (belong fttp)
There have been a lot of message here about NBN. This is a good place to start:
What is an NBN network and is my NETGEAR DSL modem router compatible? | Answer | NETGEAR Support
If you search the forum you will also find several earlier discussions about NBN and the D6400. For example, I found this one:
D6400 for NBN connection, does it work? - NETGEAR Communities
There are more where that came from:
Search results
They aren't all about the D6400, but what works for one modem probably works for the D6400.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 4
Astaraxia
thanks finally got it working!
Message 3 of 4
That's good.
For the benefit of fellow sufferers who might turn up with the same question, did you have to do anything special to get into the NBN system?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2126 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
