- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D6400 Firmware problems
- Mark as New
- Bookmark
- Subscribe
- Permalink
Upgraded from V1.0.0.96 firmware to the latest V1.0.0.102 which has been a complete disaster. Caused my Citrix connection to keep dropping, so reverted back to V1.0.0.96.
Since then, the Check if new firmware option + download it option is missing from Router Update and when I try to select Approved USB Devices receive the error message "400 Bad Request" and the option fails to work.
Is my Router on the way out or can anybody helo me fix it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D6400 Firmware problems
Have you reset the D6400?
You could also flash the firmware again, just in case it didn't stick last time around.
Caused my Citrix connection to keep dropping....
I don't know what that means – Google is unclear – but did you try to track down what the problem was.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am experiencing the same problems, cannot select Approved USB Devices anymore without the page crashing out and the password is not accepted in Windows now for password protected drives.
One note, upgraded to 104 firmware and my Citrix connection is hardly now dropping out.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
