- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D6400 NBN VOIP
- Mark as New
- Bookmark
- Subscribe
- Permalink
D6400 NBN VOIP
Is there an issue running VOIP via the D6400 on Australia's NBN FTTN services? I can receive calls but no make them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D6400 NBN VOIP
Hello Claurie
Can you give some more detail about when this happened if anything has changed in your setup?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D6400 NBN VOIP
Hi DarrenM,
We recently moved to NBN from ADSL2+ using our Netgear D6400 and an ATA from the provider to provide the Analogue to IP conversion for voice. Internet is working perfectly and we can receive VOIP calls without issue. The only problem is outgoing voice calls - receiving a recorded message that our call (reading back the number dialled correctly) has been rejected by the provider "due to error code 400".
Have you seen this before?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D6400 NBN VOIP
Hello claurie
Does the ATA need any type of port forwarding?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D6400 NBN VOIP
Hi DarrenM
We are using an Obihai OBI302 and there is no mention of Port Forwarding being required
Cheers
claurie
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D6400 NBN VOIP
Hello claurie
I found this on the Obi website
What ports should I keep open on my router/firewall?
In order for your OBi to be able to send packets w/o interruption, please configure your router as follows:
Allow Outgoing:
TCP Ports: 6800, 5222, 5223
UDP Ports: 5060, 5061, 10000 to 11000, 16600 to 16998, 19305
Allow Incoming on UDP Port: 10000
DarrenM
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
