Orbi WiFi 7 RBE973
Reply
D7000 Features request
Hi all
- where can I configure and customize ntp?
- where's the firewall panel?
- where can I find bandwidth usage statistics for each connected device?
- integration with arlo camera
thanks
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 2
TheEther
Guru
Re: D7000 Features request
@sbellisario wrote:
Hi all
NTP is not configurable.  You can only set the time zone under ADVANCED > Security > Schedule.
ADVANCED > Security.  You can Block Sites and Block Services.
You can enable ADVANCED > Advanced Setup > Traffic Meter but it won't provide usage statistics for each device.  You can view per-port statistics at Advanced > Show Statistics.  All wireless traffic, however, is lumped together.
Not available, AFAIK.
Here is the manual for future reference.
Message 2 of 2
Discussion stats
  • 1 reply
  • 1310 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
