Orbi WiFi 7 RBE973
Reply
D7000 - Firmware Problem 1.0.1.42
Andrea88
Follower
Last night, before installing the new firmware I run the reset with the button in order to do a clean installation.
After restarting, however, no longer could access the configuration page from my PC (which has always been connected via LAN), or using the ethernet cable and wi-fi.
With all other devices in the home (which have always been connected only via wi-fi) for example ipad - smartphone - notebook can access it without problems.
I am doing various tests I noticed that changing the IP address of the router eg 192.168.0.8 can access it again from my pc, but at home I have devices that have blocked the gateway 192.168.0.1, so I was forced to return at default.
I tried to switch browsers, clear the cache and reset several times / load previous firmware on the router, but without success.
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: D7000 - Firmware Problem 1.0.1.42
Hello Andrea88
You could try to load the firmware via TFTP to see if that works.
http://kb.netgear.com/app/answers/detail/a_id/22688/~/how-to-upload-firmware-to-a-netgear-router-usi...
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2242 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
