- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D7000 VOIPand WiFi Phone
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
I have a D7000v2 and I have had VOIP connected to my NBN (Australia). I purchased a WiFi phone = Grandstream WP810 who told me it works on any WiFi service regardless of the modem. Now I'm caught between the ISP saying the modem is not compatible with VOIP and the phone seller saying it doesn't need to be because it relies on WiFi and the ISP is not providing the correct SIP settings... is there anyone that might be able to shed some light here? Many thanks in advance 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D7000 VOIPand WiFi Phone
Have you looked at the manual for SIP settings?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Manage the SIP Application-Level Gateway.
Sadly, NBN is a great source of confusion. It just means "Australian Internet". It doesn't tell us how they deliver the Internet to you. The D7000v2 is a DSL modem/router. Are you using it as that? Or is it just working as a router, bypassing the modem? Or it is configured as a wireless access point? The latter would disable various features.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
I have no idea if this would affect SIP, but it does show that there are complicating factors that you need to consider.
A search of this forum might also throw up some advice. For example:
D7000 VOIP configuration - NETGEAR Communities
A broader search covers DSL modem routers:
For Oz specific advice, these people have proved useful in the past:
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
