- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D7000 on TalkTalk - Settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've been with TalkTalk for around 6 months now, the entire time I have been using my D7000 as modem and router. I recall when I subscribed to talktalk I just used the genie setup wizard and all connected ok.
Long story short, an outage yesterday led to TT telling me to factory reset my D7000 (turns out the issue was at the exchange but this is now sorted).
Now my problem is I cannot reconnect to the internet.
The setup wizard keeps telling me that I am using incorrect ISP username and pass (phone number@talktalk.net & no password).
When I use the 'advanced' settings as per the TalkTalk website I still get no connection.
I don't suppose any body could help me find where I'm going wrong?
Thanks!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D7000 on TalkTalk - Settings
Dunno what will get you back up & running (sorry) but next time before doing a factory reset, save a copy of your configuration first; then you will have that to fall-back on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Were I feeling cruel, I would say, "using TalkTalk". The world's worst ISP. I regained 10 years of my life when I move to BT, which is saying something.
Do you, by any chance, have a saved configuration file for your D7000? You could reapply that.
Anything useful here?
Search - NETGEAR Communities TalkTalk
Did you find this?
Set up a non-TalkTalk router - TalkTalk Community
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have solved exactly this problem when moving to TT from BT. I have a FTTC install, so I'm using VDSL (despite talktalk support insisting that their published ADSL settings are good for all installs).
The specific requirement is to select 'no' for 'My internet connection requires a password. Obviously the authentication stage is subsequent to establishing the channel, and with the TT configuration any 'authenticate' request results in failure (so I was seeing the connection coming up with an IP, then immediately disconnecting in the logs).
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
