- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D7000 wrong date and time after firmware update to 1.0.1.44
- Mark as New
- Bookmark
- Subscribe
- Permalink
After the firmware update to version 1.0.1.44_1.0.1 the VPN service didn't worked anymore, and I found out that the system date was set to January 01 1970.
I tried many solutions I've found on this and other forums, but none worked (DNS, port triggering for UDP 123, etc..).
The router did not synch the time anymore.
UPDATE:
I removed all the NAT rules I set up months ago, rebooted the router and BANG! the time is correct now!
I set up again the NAT rules, and the time is keeping synch correctly!!
This does not makes sense, but hope it can help someone.
StefanoV
Nighthawk D7000 Firmware Version V1.0.1.44_1.0.1
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Stefanov
Thanks for sharing this fix for the problem you ran into.
DarrenM
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Stefanov
DarrenM
