Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D7000v2 latest firmware Aug2020 1.0.0.62_101 BROKEN - Please fix!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-08-15
06:24 AM
2020-08-15
06:24 AM
Please test your hardware and software better.
First issue: The latest firmware adds a problem with pausing connectivity for ten seconds frequently but semi randomly (you can run a continuous ping (ping -t) and see this clearly) although there were unconfirmed reports of this being related to iphones on the network, I seem to see the problem regardless of it (my housemate does have an Iphone).
Second issue: if you select (it's selected by default which is why this is such a problem) "Enable 20/40MHz Coexistence" then you can no longer connect to the 2.4GHz network, and if your 5GHz share the same SSID the whole thing is unconnectable. Guest networks share the same fault if enabled.
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-08-18
03:59 AM
2020-08-18
03:59 AM
Re: D7000v2 latest firmware Aug2020 1.0.0.62_101 BROKEN - Please fix!!!
I hade same problems with d7200 v2 latest version.
Message 2 of 2
