- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D7800 Openvpn not connecting after 1.0.1.28 upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tue Dec 19 01:03:24 2017 us=526434 OpenVPN 2.4.3 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Jul 3 2017
Tue Dec 19 01:03:24 2017 us=526458 library versions: OpenSSL 1.0.2g 1 Mar 2016, LZO 2.08
Tue Dec 19 01:03:24 2017 us=526696 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Tue Dec 19 01:03:24 2017 us=526715 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Tue Dec 19 01:03:24 2017 us=527883 LZO compression initializing
Tue Dec 19 01:03:24 2017 us=527989 Control Channel MTU parms [ L:1656 D:1210 EF:40 EB:0 ET:0 EL:3 ]
Tue Dec 19 01:03:24 2017 us=558846 Data Channel MTU parms [ L:1656 D:1450 EF:124 EB:412 ET:32 EL:3 ]
Tue Dec 19 01:03:24 2017 us=558896 Local Options String (VER=V4): 'V4,dev-type tap,link-mtu 1592,tun-mtu 1532,proto TCPv4_CLIENT,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-client'
Tue Dec 19 01:03:24 2017 us=558903 Expected Remote Options String (VER=V4): 'V4,dev-type tap,link-mtu 1592,tun-mtu 1532,proto TCPv4_SERVER,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-server'
Tue Dec 19 01:03:24 2017 us=558918 TCP/UDP: Preserving recently used remote address: [AF_INET]IP_ADDRESS:12974
Tue Dec 19 01:03:24 2017 us=558940 Socket Buffers: R=[87380->87380] S=[16384->16384]
Tue Dec 19 01:03:24 2017 us=558946 Attempting to establish TCP connection with [AF_INET]IP_ADDRESS:12974 [nonblock]
Tue Dec 19 01:03:25 2017 us=559186 TCP: connect to [AF_INET]IP_ADDRESS:12974 failed: Connection refused
Tue Dec 19 01:03:25 2017 us=559492 SIGUSR1[connection failed(soft),init_instance] received, process restarting
Tue Dec 19 01:03:25 2017 us=559585 Restart pause, 5 second(s)
Can you please help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D7800 Openvpn not connecting after 1.0.1.28 upgrade
Did you revert back to the old firmware and test if it will connect again?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Betreff: D7800 Openvpn not connecting after 1.0.1.28 upgrade
Hi Adham,
I've experienced a similar problem and was able to solve it.
I've previously updated my D7800 to V1.0.1.31 (https://kb.netgear.com/000053194/). And after the update was successfull and the D7800's boot sequence was done, I've tried to use the OpenVPN connection. But the clients didn't want to connect.
So, I used a telnet connection to look into the logs. And I saw, that the datetime info in each log entry was from the 1970s.
Please make sure that you've set the time zone correctly.
Hit apply - although it might already be set correctly.
see e.g.: https://community.netgear.com/t5/General-WiFi-Routers/Setting-the-time-on-the-Router/td-p/398056
Have fun!
PS: By the way, please update your OpenVPN client to 2.4.4 (see https://openvpn.net/index.php/download/community-downloads.html)
