Orbi WiFi 7 RBE973
Reply
D7800 broken antenna
Raftenuk
Hi, my son got hold of my router and managed to bend all the antennas.
I have looked everywhere but I can’t find a place to buy a set
Thanks
Model: D7800|Nighthawk X4S – AC2600 WiFi VDSL/ADSL Modem Router
Message 1 of 4
Guru
Re: D7800 broken antenna
I think they're standard dual band antenna with standard rp-sma screw on connection.
Provided the attachment point is good, a 3rd party dual band antenna should work fine.
Message 2 of 4
Raftenuk
Hey , i went on countless websites and youtube videos and they seem to be two different antennas, now I’m more confused than ever
Message 3 of 4
Guru
You've got the router/antenna's right there.
Simply look at the end of the antenna to ensure its a rp-sma connector and buy 3rd party antenna's off amazon.
https://en.wikipedia.org/wiki/SMA_connector
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1001 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
