- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D7800 disconnects whilst using bittorrent
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've had this modem since Amazon Prime day and I am far from impressed. Random internet disconnects are pushing me to sending this back and going back to the Sky router instead.
I am using firmware 1.0.1.10. I have enabled and disabled an array of different options including DOS protection, IGMP, DMZ, SIP ALG, opening the NAS up, but every time I fire up my torrent client my internet goes down and the router must be rebooted.
The following can be seen in the log:
[DoS Attack: SYN/ACK Scan] from source: 165.254.42.56, port 80
There's also a DOS ATTACK Ascend Kill as well.
I never had this issue with my HomeHub4 nor did I have it for the one day I used the Sky router.
Does anyone have any further recommendations beyond changing every setting I can think of already?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D7800 disconnects whilst using bittorrent
Hello dkl_uk
Have you tried to use another torrent client to see if the same thing is happening?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've tried uTorrent and qBitTorrent.
I have tried three different machines, two laptops and a desktop.
Initially, wired performance seemed OK but then the disconnects happened again.
I have changed the MTU for the wireless adapter on one laptop and have reduced the global & per torrent connections.
I can watch 1080p YouTube without issue, but if I fire up a torrent client, as soon as the torrents get to about 700-800K/s the internet connection just drops. The router itself appears fine, but internet connections cease to work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello dkl_uk
Have you tried to lower the max number of connections in the bittorrent clients you use?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was able to download a windows 10 iso image direct from Microsoft last night utilising my full bandwidth capacity for an hour without issue, but the torrents disconnected me five times in less than an hour.
- Mark as New
- Bookmark
- Subscribe
- Permalink
+1 connection drops instantly when torrenting anything on any device and on any client and even limiting the amount of connections. V1.0.1.16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
switched clients and reduced connections to 100. got it to work. been pretty solid so far, couple of wan drops for no reason, looked at logs says dos attack which is bs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
