Orbi WiFi 7 RBE973
Reply
D7800 keeps dropping all device connections
sye
Hi
My R7800 keeps radomly throughout the day dropping all connection to wireless and wired devices and comes back after 30-60 secs.
I cannot see anything reported in the logs.
I have updated firmware to latest version 1.0.1.10.
It causes me alot of problems as work from home and keeps dropping the VPN to work with it and my RDP session also right in the middle of developing or debugging.
I use BT Fibre and all was ok till 2 weeks ago.
Can anyone help?
Thanks
Sye
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 5
Retired_Member
Not applicable
Re: D7800 keeps dropping all device connections
If the logs are empty it's probably rebooting for some reason.
Message 2 of 5
coolguy949
Apprentice
That's not the latest firmware for R7800. There is a newer 1.0.2.04 available: Link
Also, be sure to factory reset after updating to this firmware. That sometimes solves problems created from upgrading.
Message 3 of 5
sye
Hi Coolguy
Thanks for your reply
Apologies I have mis typed the model number, it is actually D7800 not R7800. I think the firmware is up to date as per
https://www.netgear.com/support/product/D7800?cid=wmt_netgear_organic#download
I will however try the reset to factory settings as did not do this after the last upgrade.
Thanks
Sye
Message 4 of 5
coolguy949
Apprentice
Sounds good. Factory resetting has solved my issues in the past. Let us know how it goes.
Message 5 of 5
Discussion stats
  • 4 replies
  • 3664 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
