× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
× NETGEAR would like to hear from you about specific features so we can improve your experience. To participate in this survey please click HERE.
Reply
D7800 nighthawk not recognising seagate expansion desktop drive 3TB
GUKA
Follower
Hi,
My d7800 nighthawk is not recognising my seagate expansion desktop drive 3TB, but does recognise a WD passport drive so I know that the USB1 is working.
According to this netgear website, the seagate 3TB is supported, so should work. It has been reformatted to exFAT as from what I have read this is best for large files and supports both MAC and windows.
Any advice gratefully received.
Model: D7800|Nighthawk X4S – AC2600 WiFi VDSL/ADSL Modem Router
Message 1 of 2
antinode
Guru
Re: D7800 nighthawk not recognising seagate expansion desktop drive 3TB
> According to this netgear website, [...]
   Which page?  "this netgear website" is a big place.
> [...] the seagate 3TB is supported, so should work. It has been
   "I have read" where, exactly?  You might try reading this:
      https://kb.netgear.com/24059/
      The router supports the following file system types for full
      read/write access:
> [...] but does recognise a WD passport drive [...]
   What's the file system on that disk?  (I'd guess not exFAT.)
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 360 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
