Orbi WiFi 7 RBE973
Reply
DG834Gv3 and Multicast
bingbonglong
I have a thermostat on my home network. It sends out multicast packets. I am writing an application to receive the multicast packets. If the route from the thermostat to the application DOES NOT go via my DG834Gv3 (firmware 4.01.40) router, everything works fine. If the route from the thermostat to the application DOES go via the router, the packets are lost/blocked in the router - they do not come back out the other side.
Is there a way to enable multicast functionality on this router?
Many thanks for any help.
Message 1 of 4
jmizoguchi
Virtuoso
Re: DG834Gv3 and Multicast
Most Netgear router will not support loopback so that might your issues
Message 2 of 4
bingbonglong
Thank you, but i don't understand. Can you explain a bit further?
Also, if I need a new router, what do I look out for to ensure I get one that will pass multicast packets correctly?
Message 3 of 4
jmizoguchi
Virtuoso
loopback - using pc behind the router pointing the WAN of the router hitting the LAN devices where both source and destination is in same LAN / router
Message 4 of 4
Discussion stats
  • 3 replies
  • 3526 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
