Orbi WiFi 7 RBE973
Reply
DGN 2200 v4
climbs
DGN 2200 v4
Hi to all,
a month ago I bought the router dgn 2200 v4 and I immediately had problems with my internet line: after some time of connection my internet bandwidth suddenly from 6Mb to 1.45Mb approximately.
Bandwidth limiting is done while browsing the Internet (connection is lost for a few seconds when it turn goes wrong) or when starting the router.
If i use the automatic configuration, the router attempts to pick another provider...if I specify the DNS of my provider I have the problem of the fall of internet bandwidth
My provider, after line checks, denies any responsibility.
I updated the firmware to the latest version, but the situation has not changed.
I hope for a solution to the problem and some good advice....sorry for some errors in my english.
Thanks in advance.
Message 1 of 9
Retired_Member
Not applicable
Re: DGN 2200 v4
Based on your first statement alone I would return it.
Message 2 of 9
climbs
Re: DGN 2200 v4
I've done that, unfortunately. I replaced it with an identical model, but the problem is the same. probably a faulty loading. may be obtained from another manufacturer?
Message 3 of 9
climbs
Re: DGN 2200 v4
sorry for the English ... was wondering if you can get a change by the manufacturer of the router
Message 4 of 9
jmizoguchi
Virtuoso
Re: DGN 2200 v4
Sounds like there is provision issues somewhere in telco.
It should only pick up your ISP on tel line you are using
Message 5 of 9
climbs
Re: DGN 2200 v4
or perhaps the router has settings stored by a previous agreement with another phone company
Message 6 of 9
jmizoguchi
Virtuoso
Re: DGN 2200 v4
If you didn't purchase from retail then possible branded firmware
You can not use ISP branded firmware router with different ISP provisioned line
Message 7 of 9
climbs
Re: DGN 2200 v4
Is not a branded router firmware on the box ... it was not reported anything. I still did the test with another model and it works, then it is a manufacturing defect. I'm looking for a way to return the product under warranty.
Thanks anyway
Message 8 of 9
jmizoguchi
Virtuoso
Re: DGN 2200 v4
Contact support warranty needs via portal at my.netgear.com
Message 9 of 9
Discussion stats
  • 8 replies
  • 5146 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
