Orbi WiFi 7 RBE973
Reply
DGN2200 v3 wifi problem
the_wolf
I changed the DGN2000 router to a DGN2200 used with a Samsung N13 netbook. The netbook receives the wifi signal as "excellent", 72 Mbps, but it cannot find any address I try to access. The netbook operates ok if I use a cable into the router. Our Nexus 7 pad is accessing the router useing wifi without any problem.
I have spoken to the Netgear support team and after a lot of searching and trying came up with no solution. They suggested that the netbook may be incompatable with the new router or it may need an upgrade. The netbook is about 3 years old
Does anyone have any ideas?
Message 1 of 3
jmizoguchi
Virtuoso
Re: DGN2200 v3 wifi problem
Unless there is driver update can be done NetBoot you may want try static IP on NetBook
You can also try address reservation in under LAN setup in the router GUI and try that too
Message 2 of 3
Devor
Luminary
Both routers use the Broadcom chipset. Obviously the DGN2200 is newer. Might be a DNS issue. Have you checked to make sure that the wireless card is getting DNS? Go to a command prompt and type:
ipconfig /all
And look at the wireless adapter entry. If it doesn't look right, make the necessary changes to DNS in the wireless adapter properties. Might help to compare the wired with the wireless properties.
Message 3 of 3
Discussion stats
  • 2 replies
  • 3992 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
