Orbi WiFi 7 RBE973
Reply
DGN2200V4 - Set as access point - WI FI unable to browse
FabianTnT
Follower
Good evening.
I contact you because I have a problem with the router in question; properly set the router as access point does not allow portable devices to browse. The funny thing is that if the router is freshly reset, properly set it all works perfectly, as long as we move away (disconnection) then return (reconnection) the devices (android) are unable to browse (offline without internet).
Additional informations:
- the same android devices works perfectly with other wi fi systems;
- the lan works fine.
Sorry for my english, i'm italian!
Many thanks
Model: DGN2200v4|N300 Wireless ADSL2+ Modem Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: DGN2200V4 - Set as access point - WI FI unable to browse
Hello FabianTnT
on DGN2200v4 have you made sure under the LAN settings that you have unchecked use Router as s DHCP server?
DarrenM
Message 2 of 2
Discussion stats
  • 1 reply
  • 2363 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
