Orbi WiFi 7 RBE973
Reply
DGN2200v4 - Unable to activate wireless from button
mi74Italy
Follower
Hi Guys,
Yesterday I disabled wireless on my DGN2200v4,very likely from front panel button. I can't enable it again, neither using the button nor the administration tools.
I've already tried to:
- push the button for 5-10 secs and wating for the led
- downgrade the firmware
- upgrade the firmware again to the latest version
- perform a factory reset.
None of these ways is working, wireless is still off.
Any suggestion ?
Thanks in advance,
Michele
Model: DGN2200v4|N300 Wireless ADSL2+ Modem Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: DGN2200v4 - Unable to activate wireless from button
Hello mi74Italy
Have you checked in the wireless settings that the Enable SSID broadcast is enabled as well? You may want to try another factory reset make sure you are holding down the button for 10 seconds. If the wireless is still not working contact Netgear support if your modem is still under warranty.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
Message 2 of 2
Discussion stats
  • 1 reply
  • 2230 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
