Orbi WiFi 7 RBE973
Reply
DGN3500 how disable wps
marcomg
Follower
I would like (for security reasons) disable WPS, but I can't flag the options. The html code of the option in config page is
[HTML]Disabilita numero PIN del router[/HTML]
It is disabled 😕
This is the page:
How can I disable WPS?
Message 1 of 2
jmizoguchi
Virtuoso
Re: DGN3500 how disable wps
http://kb.netgear.com/app/answers/detail/a_id/19824
This is usual the common way to disable.
In some "older" unit they have not gotten any firmware upgrade after vulnerability of WPS
If you do not see it you can contact support if they are release any firmware that adds those features via portal at my.netgear.com
Message 2 of 2
Discussion stats
  • 1 reply
  • 3893 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
