Orbi WiFi 7 RBE973
Reply
DGND3700v2 N600 Wireless Dual Band Gigabit ADSL2+ Modem Router
barb161
Follower
Can someone tell me what I can do, I have set the times for 7am to 5pm to shut off my intranet with the kids out of school I dont want them on it all day. They are shutting the router off and then back on and it turns the intranet back on even though I have the times for it to shut off.  How do I stop them from getting on the wifi.
Thanks
Message 1 of 3
Guru
Re: DGND3700v2 N600 Wireless Dual Band Gigabit ADSL2+ Modem Router
If they've figured out that a reboot will temporarily fix the issue, just take the power cord when you leave. Really tough to reboot it then.
Message 2 of 3
The DGND3700v2 is an old (2014) DSL modem/router. It has few of the parental controls that come with newer devices.
It does have the ability to schedule some things that might help to control their access.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Schedule for Firewall Rules.
Message 3 of 3
Discussion stats
  • 2 replies
  • 698 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
