Orbi WiFi 7 RBE973
Reply
Disconnects - D3600 - N600
Alexfahey
Follower
Hi,
I have just bought a N600 WiFi modem router and cannot get solid connection through it. After I turn it on I get approx 5 mins Internet then it completely stops working. The WiFi signal in bottom right windows 10 says connected with Internet access but cannot even open a Web page. In my netgear genie app it says that the Internet port in advanced setting has a red Cross and is disconnected. When I reconnect it the Internet works again but shortly turns off again. How can I make the connection stable?
Thanks
Alex
Message 1 of 2
Re: Disconnects - D3600 - N600
Is this a solid wifi connection?
If so, how have you got the wifi configured?
You can find the manual here:
D3600 | Product | Support | NETGEAR
Page 55 is where the wifi settings begin.
Page 195 is all about troubleshooting WiFi Connectivity.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1552 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
