Orbi WiFi 7 RBE973
Reply
Ethernet cable disconnects internet on Macbook
BSCJ
Have just installed Netgear AC1200 WiFi Modem Router.
We have a PC, a Surface and A Macbook Pro.
Wifi works OK on all of these devices.
Cable connection is fine with the PC but when connected to the Mac in another room (by ethernet to USB adaptor), the internet connection to the Mac becomes disabled after a short while (about 10-20 seconds).
This cable worked fine with our old Belkin modem just hours ago.
Have tried cycling the modem, cycling the Mac, switching off WiFi on the Mac, pressing the WiFi button on the modem.
Is this a switching issue? It seems as soon as the Mac sees the cable it disconnects from the net.
Great to have WiFi working but we bought this new modem to have the option to easily switch off WiFi and just use cable connections when we are in our office.
I am certainly not technically gifted, so hope there is some fairly simple thing to do. Would really appreciate some advice on how to fix this.
BSCJ
Model: D6200v2|AC1200 WiFi DSL Modem Router
Message 1 of 3
Accepted Solutions
BSCJ
Re: Ethernet cable disconnects internet on Macbook
Thanks for your help Darren. Problem is now resolved. Was a coincidental fault in one cable link.
B
Message 3 of 3
All Replies
DarrenM
Sr. NETGEAR Moderator
Hello BSCJ
Do you have the latest drivers for your usb or that adpater?
DarrenM
Message 2 of 3
BSCJ
B
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 6455 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
