Orbi WiFi 7 RBE973
Reply
Guest Network - not allowing security option
Linkin86
Follower
Hello Everyone
I have the N300 DGN2200MV2 router. I am trying to set up a guest network. It allows me to name and enable the SSID and broadcast option fine, however when I try and apply security measures it refreshes and clears the Guest Network name and sets the security measure option back to the default option of "None".
If I go through the process and choose not to apply a security measure on the guest network, then I am able to set it up fine - but of course I would like to have the guest network secured and not open...
I have only attempted to setup the guest network via phone and not while hardwired to the router itself - could this be the issue?
Any help would be much appreciated!
Regards
Model: DGN2200M-2TKSAS|N300 Wireless ADSL2+ Modem Router - Mobile
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Guest Network - not allowing security option
Have you tried to do this using a different web browser or make sure no firewall or pop up blocker is stopping the change from occurring?
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 855 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
