Orbi WiFi 7 RBE973
Reply
How to turn off broadcasting for FVS318v3?
KenRo2
Follower
We recently had a fiber connection run to our office with a single static IP and /31 subnet. When we try to re-program the router, recieve an error messsage stating the IP address is a broadcast address in the 254 subnet. Cannot find anything in the firewall software that allows us to turn off broadcasting (which we don't need since we have a single static IP).  Help?!
Message 1 of 2
TheEther
Guru
Re: How to turn off broadcasting for FVS318v3?
The router probably doesn't have support for /31 subnets (see RFC 3021).  You can try configuring your side as a /30 subnet.  This may not necessarily work.  If the host bits in the IP address to your ISP's router are zero, then the Netgear may balk.  Try using a shorter subnet mask until you get some non-zero host bits.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2738 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
