Orbi WiFi 7 RBE973
Reply
Is Netgear AC1600 model d6400 a router or a modem?
MarioHere
I'm confused. on Amazon page, the seller say its not a modem, but on the back of the device it says AC1600 Wifi VDSL/ADSL Modem Router Model d6400
Message 1 of 4
Re: Is Netgear AC1600 model d6400 a router or a modem?
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
It might help if you pointed people to the Amazon page.
NETGEAR D6400-100UKS AC1600 Dual Band 300 + 1300 Mbps Wireless (Wifi) VDSL/ADSL Modem Router for Pho...
Message 2 of 4
Guru
Its kind of both.
the D series of devices have an integrated dsl modem into them.
they can also just function as a router only device.
Or just a modem only device.
So based on how you set it up, depends on if it runs as a dsl modem with router, just a router, or just a dsl modem.
the manual is as @michaelkenward showed you so you could set it up as you prefer.
Message 3 of 4
From personal experience, I don't recommend that.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1648 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
