Orbi WiFi 7 RBE973
Reply
NetGear Ac1900
Laws304
Follower
NetGear Ac1900
Modem was working fine til minor upgrade with Centurylink..now the internet light is amber, everything else is white, have called Centurylink 19 times about this issue & they tell me it is MY problem. I upgraded by 5 mgbs.. we have no internet.. do I need a new modem or keep bugging Centurylink?
Model: R8900|Nighthawk X10 AD7000 Smart WiFi Router
Message 1 of 3
antinode
Guru
Re: NetGear Ac1900
> NetGear Ac1900
   "AC1900" is a speed, not a model number.  Look for "Model" on the
product label.  Firmware version?
   Nothing to do with anything?
> [...] minor upgrade with Centurylink. [...]
   How "minor" was it, would you say, if it caused your service to stop
working?
> [...] now the internet light is amber, everything else is white, [...]
   "everything else", or just those parts of "everything else" which you
consider significant?  (And who else knows what those might be?)  What
does the DSL indicator indicate?  (Or ADVANCED > ADVANCED Home :
Internet Port : Show Statistics : Link Rate (et c.))
> [...] I upgraded by 5 mgbs.. [...]
   Mb/s?  "upgraded" from what to what, exactly?
> [...] do I need a new modem or keep bugging Centurylink?
   It depends.  If your new CenturyLink service uses a bonded pair of
lines, then your Netgear modem(+router), whatever it is, would be
useless.
      https://kb.netgear.com/30296
   If your modem+router is configured incorrectly (PPPoA v. PPPoE, or
any number of DSL-related parameters), then that could cause trouble.
But I know nothing about your old configuration or your new one.  Or
what CenturyLink told you about either.
   Firmware defects in many Netgear models cause problems with special
characters in PPP credentials.  But, again, I can't see what you're
doing, before or after.  Or if such parameters have changed with this
"minor upgrade".
      https://community.netgear.com/t5/x/x/m-p/1354547
   As a first step, if bonded lines are not involved, I might try a
settings reset, and let the set-up wizard try to puzzle out the proper
DSL settings.
Message 2 of 3
Re: NetGear Ac1900
What modem is this? Netgear makes about half a dozen AC1900 modems, cable and DSL.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1072 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
