Orbi WiFi 7 RBE973
Reply
Netgear D6300 modem 5gh wifi is not showing up..!!!
Amit5098
Follower
Hi there,
I have  D6300 (ac1600)  modem connected to NBN using No isp username/password required.
Issue:  5Ghz ssid is not showing up
wired Internet is working fine. 2.4GH works perfect and good strength.
tried the following:
(1) rebooting few times
(2) hard reset using the pin at the back of the modem
(3) changing channels on 5ghz and 2.4ghz
(4) unchecked and checked advance wifi radio buttons
Nothing works..!!!
what do I do, please help.
Model: D6300|Dual Band 11ac ADSL Modem Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Netgear D6300 modem 5gh wifi is not showing up..!!!
Have you tried to change the Name of the SSID?
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1038 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
