Orbi WiFi 7 RBE973
Reply
Netgear D7000 AC1900 WiFi VDSL/ADSL readyshare issues
Majorstrife
Follower
I can not connect to my connected hard drive using readyshare. I keep getting registation failure when I go through the process steps on the router home page. Reading this seems to be a common issue. Has anyone found a solution to the issue.
Tried a few of the other solutions posted on here change password to a simple combination. Reset router, copy and paste password but still no luck.
Message 1 of 2
Re: Netgear D7000 AC1900 WiFi VDSL/ADSL readyshare issues
Can you take us through the steps you take and where they go wrong?
Start with the hard drive. What is it?
Is this a ReadyCloud connection?
Does the thing work with Basic?
There is support for the D7000, including a manual, somewhere at the end of this link:
>>> D7000 | Product | Support | NETGEAR <<<
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 516 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
