Orbi WiFi 7 RBE973
Reply
Netgear D7000 connecting with Zmodo issues
avel
Follower
I recently purchased and set of the D7000  and it has worked great but I can not get it link up with Zmodo Pivot Security Camera. Zmodo Tech says that it is required to be on 2.4Ghz which is shown on my settings. Not sure what to do at this point on it.
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Netgear D7000 connecting with Zmodo issues
Hello Avel
You can try to change the wireless channel and the security type. If the camera has WPS try connecting it that way.
DarrenM
Message 2 of 2
Discussion stats
  • 1 reply
  • 2168 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
